17255 Discussions
how to declare dynamic port size depending on generic
Hi, Can anyone tell me how to declare a port with its size determine by a generic in VHDL?
For example:
ENTITY tone_det IS
generic(FRAME_SIZE: integer := 63;
PORT(
OUTPUT : std_logic_vector (5 downto 0);
END tone_det;
Here, the OUTPUT has a fixed size of 5 because 2^6-1=63. 63 is the frame size...but how to declare this dynamically? so everytime I change my generic (in a higher level design file), this OUTPUT size will be changed accordingly? For example, if generic is defined as 127, then the bus width should be 6
Instead of defining FRAME_SIZE, define FRAME_WIDTH, then later inside your architecture define
constant FRAME_SIZE : integer := 2**FRAME_WIDTH-1;
Or, have two generics, FRAME_SIZE and FRAME_WIDTH, and where ever you instantiate the component have code in that architecture that defines
library ieee;
use ieee.math_real; -- ceil and log2
constant FRAME_SIZE : integer := 64;
constant FRAME_WIDTH : integer := integer(ceil(log2(real(FRAME_SIZE))));
u1: tone_det
generic map (
FRAME_SIZE => FRAME_SIZE,
FRAME_WIDTH => FRAME_WIDTH
port map (
Cheers,
Dave
