17255 Discussions
how to map many ports to a vector/array ?
Hi All,
I have an entiry with a lot of ports. I'd like to map these ports to a vector/array.
example
Ports:
bit_000_0 : in std_logic;
bit_000_1 : in std_logic;
bit_000_2 : in std_logic;
bit_000_3 : in std_logic;
bit_000_4 : in std_logic;
Desired mapping of the ports to a vector:
vec (0) <= bit_000_0;
vec (1) <= bit_000_1;
vec (2) <= bit_000_2;
vec (3) <= bit_000_3;
vec (4) <= bit_000_4;
Can I use a function/package for this purpose? There are a lot of such ports (~150), so I'd like to do these assignments in the separate file (e.g. package) and do not clutter the top entity/module file. Is this possible?
Thank you!
Concatenation:
vec(4 downto 0) <= bit_000_4 & bit_000_3 & bit_000_2 & bit_000_1 & bit_000_0
--- Quote Start ---
Concatenation:
--- Quote End ---
Could this assignment be done in the package? Remember that bit_000_4, bit_000_3, ... are ports - could they be observed from a package?
Because they are all single bits, then concatenation is about the only thing you can do.
