how to use clk in fsm
hey..I want to build a final state machine embodies eight numbers and then she proceeded to tell the eighth.For example if the eight number is four I want the machine extract four pulses of 1 clock cycle difference between between pulses and then wait another 10 clock cycles and then switches to the next state( and in the next do the same thing).The problem that he dosent let me use the clock in the states ..Does anyone have an idea what to do?The code
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity pulsim is
port(
resetN, clk : in std_logic;
da : in std_logic_vector(3 downto 0) ;
db : in std_logic_vector(3 downto 0) ;
dc : in std_logic_vector(3 downto 0) ;
dd : in std_logic_vector(3 downto 0) ;
de : in std_logic_vector(3 downto 0) ;
df : in std_logic_vector(3 downto 0) ;
dg : in std_logic_vector(3 downto 0) ;
dh : in std_logic_vector(3 downto 0) ;
sinus : out std_logic);
end pulsim ;
architecture behavioral of pulsim is
type state_type is (s0,s1,s2,s3,s4,s5,s6,s7);
signal current_s,next_s: state_type;
signal countera : std_logic_vector(4 downto 0) :=dh &'0' ;
signal counterb : std_logic_vector(4 downto 0) :="01010" ;
signal cinout : std_logic ;
begin
process ( resetN , clk)
begin
if resetN = '0' then
current_s <= s0;
elsif (rising_edge(clk)) then
current_s <= next_s;
end if;
end process;
process (current_s,dh,clk)
begin
sinus <= cinout ;
case current_s is
when s0 => --when current state is "s0"
if(dh ="1111") then
cinout <= '0';
next_s <= s0;
else
if rising_edge(clk) then
if countera /= "00000" then
countera <= countera-"00001";
cinout<= not(cinout);
counterb<="01010";
elsif (countera = "00000") and (counterb/="00000") then
counterb <= counterb-"00001";
cinout <= '0' ;
else
counterb<="01010";
countera<=dg &'0';
next_s <= s1;
end if;
end if;
end if;
when s1 =>
cinout <= not (cinout) ;
counterb<="01010";
cinout <= '0' ;
else
counterb<="01010";
countera<=df &'0';
next_s <= s2;
end if;
end if;
when s2 =>
counterb<="01010";
cinout <= '0' ;
else
counterb<="01010";
countera<=de &'0';
next_s <= s3;
end if;
end if;
when s3 =>
counterb<="01010";
cinout <= '0' ;
else
counterb<="01010";
countera<=dd &'0';
next_s <= s4;
end if;
end if;
when s4 =>
counterb<="01010";
cinout <= '0' ;
else
counterb<="01010";
countera<=dc &'0';
next_s <= s5;
end if;
end if;
when s5 =>
counterb<="01010";
cinout <= '0' ;
else
counterb<="01010";
countera<=db &'0';
next_s <= s6;
end if;
end if;
when s6 =>
counterb<="01010";
cinout <= '0' ;
else
counterb<="01010";
countera<=da &'0';
next_s <= s7;
end if;
end if;
when s7 =>
cinout<= not (cinout) ;
counterb<="01010";
cinout <= '0' ;
else
counterb<="01010";
countera<=dh &'0';
next_s <= s0;
end if;
end if;
end case;
end process;
end behavioral;
thanks..
You have to define state transition more clever. <- the problem begins here. Try write down it on the notebook paper or/and use builtin FSM tool in Quartus.
Then you command your FSM to saty in state in which it will pulse-out. It is good if you use counter which counts down to zero each clock cycle and you allow the clock signal to go trough "clever" AND-gate to pulse-out.
