i attached file & picure.
our team creating uart verilog code. by using modelsim. i have 4 modules for FPGA and one module for simulation as like testbench. so i will explain shortly. in code, when transmit is 1, enable= 1 ( it create one clock) transmit ________l------------l____________________ enable __________--___________________________ but, i coudln't fix that problem... when i run code, output wire enable is not connected. the code is in '"module dld" Thank you.Link Copied
we didn't put rx. we just put tx code. not rx.
You did not initialize the reset value for reg a and reg b in module "dld". Like reg a=0,b =0; Or change the always process like below
always @ (posedge clk or posedge reset) if begin a <= 0; b <= 0; end else begin if(counter == 12'd2604) begin a <= transmit; b <= ~a; end end- Mark as New
Thank you for your help. I appreciate. Haha thanks! I was not good yesterday about feeling but right now I feel happy ! Thanks again. Sleep well !! Good night
--- Quote Start --- You did not initialize the reset value for reg a and reg b in module "dld". Like reg a=0,b =0; Or change the always process like below always @ (posedge clk or posedge reset) if begin a <= 0; b <= 0; end else begin if(counter == 12'd2604) begin a <= transmit; b <= ~a; end end --- Quote End --- Thank you for your help. I appreciate. Haha thanks! I was not good yesterday about feeling but right now I feel happy ! Thanks again. Sleep well !! Good night
