illegal character
i have installed quartusII 10.0 on windows 7. I am not able to open project because of the error "The project or revision name contains one or more of the following illegal characters and cannot be opened : ^&?*|<>;' ". The same 10.0 installed on an XP machine and with the same project don't give the error. What can it be??
Thank you
What is the name of the project?
Thank you,
DONE. My error, not in the project, but in the path to the project...
--- Quote Start ---
Thank you,
--- Quote End ---
pls can you explain to me how you did this because i am finding the same problem
Hi & Good Day!
I am facing the same problem, how do you fix it?
New Learner.
Thanks in advance.
Hi capitano,
Mind share further on the issue and fix? Thanks.
This usually occurs when you have spaces in the file path
Hi & Good Day!
Actually my location of files is not on the right place, I just need to change my directory file to the "c:\altera\90sp2\quartus\YourFile
