17249 Discussions
include file in a vhdl file ...
I need to include a computer generated vhdl file (including constants) in another vhdl file. I could generate the full file (so the header etc etc ) with my C code,
but would be more clean to include the constants separately in the hand written file. Just to explain:
CURRENTLY:
use ieee.std_logic_unsigned.all;
package common_defs is
-- constant
constant ENGINES_NUMBER : integer := 3; -- number of instanciated engines
-- Types
type INTERSECT is array (0 to 5) of std_logic_vector(11 downto 0);
type INTERSECT_ARRAY is array (0 to ENGINES_NUMBER) of INTERSECT;
constant ENGINE_INT_X : INTERSECT_ARRAY := ((X"010",X"020",X"030",X"040",X"050",X"060"),
(X"010",X"020",X"030",X"040",X"050",X"060")) ;
constant ENGINE_INT_Y : INTERSECT_ARRAY := ((X"011",X"021",X"030",X"040",X"050",X"061"),
(X"011",X"021",X"030",X"040",X"050",X"061")) ;
end common_defs;
While I'd like something :
-- constant
-- Types
INCLUDE constants.vhd; -- HOW DO I DO IT ?????????????????????????????????????
end common_defs;
and constants.vhd is like:
and it is computer generated.
Is that possible ?
thanks
franco
you define a package called constants and use it like you did the other libraries
Use work.constants.all;
There is no pre-processor in VHDL like there is in C or Verilog, so you cannot just include another load of text. It has to be a compiled package.
PS, Why are you using the non-standard std_logic_unsigned library?
