17255 Discussions
instantiating megafunctions
I am new to Verilog, I would like to find the syntax in Quartus II to instantiate a megafunction
in a module. I have built the function and created the .v file using the megafunction wizard but
I am getting a lot of syntax errors after compilation. If anyone could point me to the syntax or to an example
it would be greatly appreciated. :confused:
Thank you very much!
Larry
Some (most? all?) MegaFunctions will generate a corresponding _inst.v file that you can copy&paste into your module and change names around etc.
On the Summary tab in the wizard, check the checkbox next to the _inst.v to get it generated for you.
