- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
i am having a problem regarding internal latches.
i have joined two blocks using a block diagram file. when i compile the whole .bdf file it compiles successfully. bt it shows warning that internal latches of 2nd blocks are permanently disabled. when i compile .vhd file of 2nd block separately then also it shows the same warnings. so i am not able to see those latches in my vector waveform file. what may be the problem?? please reply fast if any one knows the solution.. thank you.Link kopiert
0 Antworten
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
