hi,
Is the pof2dat.pl or rpd2dat.pl script still usable in Quartus 7.2 version? I try to use these scripts to check my pof file and eventually I want use pci to write the 2 RPD files to EPCS64 device. Since I cannot find these scripts in 7.2 Version. I just "borrow" them from 6.1 version. But It always report "failed to find 0x6A marker in pof file" error. I understand that there is length indication after 0x6A and I want to strip off the useless data when I write data to EPCS device. People in the forum should said before too. But not in any document of Altera. My sof/pof file should be no problem (it works by using programmer download). So what is the problem of this? Is the script still usable in high version? Or is it work for EPCS64 device? thanks in advance.Link Copied
Topic Options
