17255 Discussions
jk flip flop usin dataflow model
How to design jk flip flop using dataflow model.
When i run the code it shows an error "iteration limit reached".
my vhdl code is
library ieee;
use ieee.std_logic_1164.all;
entity jkff_dataflow is
port(j,k,clk,rst:in std_logic;
q,qbar:inout std_logic);
end jkff_dataflow;
architecture jkff_dataflow of jkff_dataflow is
begin
q<=(((k and clk) and qbar) nor qbar) nor rst;
qbar<=((j and clk) and q) nor q;
end jkff_dataflow;
You hehe created a logic loop. Q depends on qbar, and q bar depends on q, so it gets in an infinite loop. Q and q bat styles not be linked.
Also, you should be using the clk signal as a clock, bout a logic signal.
--- Quote Start ---
--- Quote End ---
so to design jk flip flop I need to use behaviour modeling. so I cannot write code by using data flow model.
In don't know what this data flow model is you're talking about. Vhdl describes a logic circuit, hence it can only be a behaviour. Your code just describes a logic loop.
--- Quote Start ---
--- Quote End ---
A data flow model is a higher-level construct. A JK flip-flop is just an implementation detail.
