A simple one I think:
Could somebody tell me the definition of 'keepers' that I'm using in my sta reporting, as in 'get_keepers'. How does it differ from 'registers' or 'ports'. Can't seem to find a definition in the documentation.Link Copied
--- Quote Start --- A simple one I think: Could somebody tell me the definition of 'keepers' that I'm using in my sta reporting, as in 'get_keepers'. How does it differ from 'registers' or 'ports'. Can't seem to find a definition in the documentation. --- Quote End --- Hi Witty, Terminology Definition: nodes: Most basic timing netlist unit. Use to represent ports, pins, and registers. keepers: Ports or registers. (1) cells: Look-up table (LUT), registers, digital signal processing (DSP) blocks, TriMatrix memory, IOE, and so on. (2) pins: Inputs or outputs of cells. nets: Connections between pins. ports: Top-level module inputs or outputs; for example, device pins. For more info's look into: http://www.altera.com/literature/hb/qts/qts_qii5v3_02.pdf in the timequest chapter. Kind regards GPK
It would help when searching if I spelt it 'keepers' and not 'kepers' :)
