large divider VHDL
hi, i have to perform a division 112 bit dividend and 112 bit divisor.
To enhance precision (fractional), i shift the numerator by 6 to the left.
To perform this huge division, i perform multiple subtraction until numerator is positive.
if (numerator positive)
Numerator <= Numerator - Denominator
Quotient <= quotient +1;
when i check for timing, the subtractor path is the most critical, i think because of the bus size.
How can i speed this task?
Numerator and denominator don't change every clock cycle, so i could use a multicycle. How i use this?
I would use lpm_add_sub to pipeline the subtractor, i have quartus 12 and this is not present in the megawizard. How i can instantiate in my vhdl?
The problem with this approach is that with small denominator the algorithm take a lot of time to complete. Think it if denominator is 1 and numerator a huge number.
In this thread:
http://www.alteraforum.com/forum/showthread.php?t=38334
I give the steps of a more efficient algorithm to divide.
i have a lot of time for division so is not an efficienty problem,
the problem, like in your approach, is that i have a 112 dividend and divisor and the substraction is slow.
i tried to do a multicycle
when en = 1 i do dividend - divisor
when en = 0 i do nothing
en change at half rate
these are the constraint
# Setup multicycle of 2 to enabled driven destination registers
set_multicycle_path 2 -to [get_fanouts [get_pins enable_reg|q*]
-through [get_pins -hierarchical *|*ena*]] -end -setup#Hold multicycle of 1 to enabled driven destination registers
set_multicycle_path 1 -to [get_fanouts [get_pins enable_reg|q*]
-through [get_pins -hierarchical *|*ena*]] -end –hold
I understand your point. You tried to add a clk enable. It's like a pipeline. One time a did a similar huge vector and didn't improve the speed. Try improve the design slow down the clk_en signal. One tick per 10 clocks, for example.
yes with clock enable i can meet setup constraints, i found a core on opencores that makes division like you said before, much faster
