17268 Discussions
little code problem in simulation
Hello everyone,
I have a little code problem that I can't resolve.
All the signals are green except the "uit" signal.
Can anyone see in the code what the problem is ?
Here is the file:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity debouncer is
port (
clk: in std_logic;
clk_enable: in std_logic;
rst: in std_logic;
cha: in std_logic;
syncha: out std_logic
--up_down: in std_logic;
--count_out: out std_logic_vector(3 downto 0)
end debouncer;
architecture behav of debouncer is
signal pres_shift, next_shift: std_logic_vector(3 downto 0);
signal sh: std_logic;
begin
next_shift <= pres_shift;
--synchroon proces, geklokt
syn_count: process(clk,clk_enable)
begin
if rising_edge(clk) then
if rst = '1' then
pres_shift <= (others => '0');
else
pres_shift <= next_shift;
end if;
end if;
end process syn_count;
--combinatorisch proces, niet geklokt
com_shift: process(pres_shift, next_shift)
begin
if(next_shift = "0001") then -- dit is voor 4 bits
next_shift <= cha & pres_shift(3 downto 1);
else
next_shift <= (others => pres_shift(0));
end if;
end process com_shift;
end behav;
And here is the testbench:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity debouncer_tb is
end debouncer_tb;
architecture structural of debouncer_tb is
-- Component Declaration
component debouncer
port (
clk: in std_logic;
cha: in std_logic;
rst: in std_logic;
syncha: out std_logic;
end component;
for uut : debouncer use entity work.debouncer(behav);
constant period : time := 100 ns;
constant delay : time := 10 ns;
signal end_of_sim : boolean := false;
signal clk: std_logic;
signal rst: std_logic;
--signal up_down: std_logic;
--signal count_out: std_logic_vector(3 downto 0);
--signal cha: std_logic;
signal syncha: std_logic;
signal button: std_logic;
signal uit: std_logic;
signal clk_enable: std_logic;
BEGIN
uut: debouncer PORT MAP(
clk => clk,
rst => rst,
clk_enable => clk_enable,
cha => button,
syncha => uit);
--up_down => up_down,
--count_out => count_out);
clock : process
begin
clk <= '0';
wait for period/2;
loop
clk <= '0';
wait for period/2;
clk <= '1';
wait for period/2;
exit when end_of_sim;
end loop;
wait;
end process clock;
tb : PROCESS
procedure tbvector(constant stimvect : in std_logic_vector(1 downto 0))is
begin
--up_down <= stimvect(1);
button <= stimvect(1);
rst <= stimvect(0);
clk_enable <= '1';
wait for period;
end tbvector;
BEGIN
tbvector("00");
wait for 1*period;
tbvector("01");
wait for 3*period;
tbvector("00");
wait for 2*period;
tbvector("10");
wait for 3*period;
--tbvector("00");
--wait for 10*period;
--tbvector("10");
--tbvector("10");
--tbvector("00");
--tbvector("00");
--tbvector("01");
--tbvector("01");
end_of_sim <= true;
wait;
END PROCESS;
END;
Do you see that output signal syncha is driven anywhere? I don't.
Solution ?
I just downloaded a few courses. I will look again.
Thanks for the reply.
