Timing issue
Hi ,
i compile my project with Quartus and i have critical error :
"Timing requierements not met" and the TimeQuest Timing Analyzer painted red .
The clk_in Frequency to the FPGA is 25MHz entered to internal PLL and spread to all the components : c0=25MHz,c1=100MHz .
At the compilation report(painted red) : under Fast 1200mV 0c Model :
Hold summery :
clk_in : slack = -0.129, End point TNS = -0.127
under worst case timing path : the signal lock at Rx comoponent that is sampled by clk_in has Clock skew =1.5,
data delay=1.525,slack=-0.129 .
i sampled the ports of my project using signal tap with the clk_in = 25MHz and the Transmitted signals working properley but the received signals not working properley .
how can i solve the timing issue ?
summery file attached .
Why do you have 1.5ns of clock skew? Is this from an incoming I/O port, or something within the device? (I/O always have clock skew, while internally you can often get around it). Basically, is this a real path that needs to be analyzed and meet timing, and does it make sense to have 1.5ns of skew?
If it's an I/O path, can you increase the delay chain in the I/O? Maybe assign the input register to a location further from the I/O? (It's really hard to say without more information, so just some quick ideas.)
Hi ,
i didn't define anything at the sdc file except the cycle time of the input clk that entered to the PLL .
The signal lock is output port - his role is to Turn on Led when he low . i sample this signal with clk_in at the signal tap .
i didn't define any thing about it at sdc file . is it matter if the clock skew is 1.5ns? do i need to change the sdc file ?
or , do you suggest to add registers to the output path of lock in order to increase the delay ?
what about the Hold issue ?
thanks .
