I am currently using de1 board and Altera quartus II software. as a beginner to digital design, I am learning by going through the Altera lab exercise. I am stacked on trying to design a 4bit t ff based counter. my code counts up to7 without problem but it won't go further I was intending to count from 0 to 15 by instantiating my t ff 4 times as shown in the code below. Will you pleas help identifying my error?
module counter_4bit(q, En, Clk, Clr, ); input En, Clk, Clr; output [0:4] q; wire [0:2] temp; tflipflop T0(q[0], En, Clk, Clr); tflipflop T1 (q[1], q[0], Clk, Clr); and(temp[0], q[1], q[0]); tflipflop T2 (q[2], temp[0], Clk, Clr); and(temp[1], q2, q1, q0); tflipflop T3 (q[3], temp[1], Clk, Clr); endmodule module tflipflop(Q, t, Clk, Clr); input t, Clk, Clr; output reg Q; initial Q = 0; always @(posedge Clk) if(Clr) Q = 0; else Q = Q ^ t; endmoduleLink Copied
The second AND has typo at q2, q1 and q0.
They should be q[2], q[1], and q[0]. Without the brackets, the identifiers are treated unrelated to q[0:4].
