17255 Discussions
lpm_decode bus output instead of individuals
How do I get the MegaFunction Wizard to generate me an lpm_decode symbol for BDF use that uses eq[] instead of the individual outputs?
--- Quote Start ---
--- Quote End ---
as far as I know it is not possible. You have to do it by your own.
Kind regards
GPK
If you do not use the wizard and just place the symbol you will get an eq[] output.
Then right click the symbol, select properties, then change ports, parameters etc.
rfournier
