17255 Discussions
making first "adder" and "fir" - using lpm lib
hi, i have some problems with compiling using two different projects with eachother.
The first I've made was an adder. Therefor I've used the adder_sub_component in the quartus42/lib/lpm file and made my own body around it:
code of adder
--- Quote Start ---
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY lpm;
USE lpm.all;
ENTITY adder IS
GENERIC (
width: integer := 10);
PORT
cin : IN STD_LOGIC ;
clock : IN STD_LOGIC ;
a,b : IN STD_LOGIC_VECTOR (width-1 DOWNTO 0);
outp : OUT STD_LOGIC_VECTOR (width DOWNTO 0)
END adder;
ARCHITECTURE arc OF adder IS
SIGNAL cint : STD_LOGIC ;
SIGNAL sumint : STD_LOGIC_VECTOR (width-1 DOWNTO 0);
COMPONENT lpm_add_sub
GENERIC (
lpm_direction : STRING;
lpm_hint : STRING;
lpm_pipeline : NATURAL;
lpm_type : STRING;
lpm_width : NATURAL
PORT (
dataa : IN STD_LOGIC_VECTOR (width-1 DOWNTO 0);
datab : IN STD_LOGIC_VECTOR (width-1 DOWNTO 0);
cout : OUT STD_LOGIC ;
result : OUT STD_LOGIC_VECTOR (width-1 DOWNTO 0)
END COMPONENT;
BEGIN
outp <= cint&sumint(width-1 DOWNTO 0);
lpm_add_sub_component : lpm_add_sub
GENERIC MAP (
lpm_direction => "ADD",
lpm_hint => "ONE_INPUT_IS_CONSTANT=NO,CIN_USED=YES",
lpm_pipeline => 1,
lpm_type => "LPM_ADD_SUB",
lpm_width => width
PORT MAP (
dataa => a,
datab => b,
cin => cin,
clock => clock,
cout => cint,
result => sumint
END arc;
--- Quote End ---
next i wanted to make a fir-filter (the most simple thing ever) using my own adder. this is: the adder with first input is input signal of fir and second input is again the fir's input but with one clock time delay and the output of the adder is the output of the fir.
code of fir
--- Quote Start ---
library ieee;
use ieee.std_logic_1164.all;
entity fir is
GENERIC (
port( inp: in std_logic_vector(width-1 downto 0);
clock: in std_logic;
outp: out std_logic_vector(width downto 0)
end fir
architecture arc of fir is
signal hulp: std_logic_vector(width-1 downto 0);
component adder
GENERIC (
width: integer);
port (
outp : OUT STD_LOGIC_VECTOR (width DOWNTO 0));
end component;
begin
fir1: adder
generic map (width:= width);
port map ( inp <= a,
hulp <= b,
outp <= outp,
clock <= clock
end arc;
--- Quote End ---
now this are my errors when compiling:
comiling errors
--- Quote Start ---
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 4.2 Build 156 11/29/2004 SJ Web Edition
Info: Processing started: Tue Oct 30 15:02:42 2007
Info: Command: quartus_map --import_settings_files=on --export_settings_files=off fir -c fir --generate_functional_sim_netlist
Error: Verilog HDL syntax error at fir.vhd(14) near text "architecture"; expecting ";"
Error: Verilog HDL syntax error at fir.vhd(16) near text "component"; expecting "end", or "begin", or a declaration statement,
Error: Verilog HDL syntax error at fir.vhd(27) near text ":="; expecting ")", or ","
Error: VHDL error at fir.vhd(26): object "adder" is used but not declared
Error: VHDL syntax error at fir.vhd(33): name used in construct must match previously specified name "fir"
Error: Ignored construct fir at fir.vhd(4) because of previous errors
Info: Found 0 design units, including 0 entities, in source file fir.vhd
Error: Quartus II Analysis & Synthesis was unsuccessful. 6 errors, 0 warnings
Error: Processing ended: Tue Oct 30 15:02:43 2007
Error: Elapsed time: 00:00:01
--- Quote End ---
its realy strange that i get errors of VERILOG - and I'm programming in VHDL..
I know its a lot of text here but i hope someone can give me an answer!
I'm using QUARTUS 2 webversion.
thanks!
The first error:
--- Quote Start ---
--- Quote End ---
Two lines up (line 12):
end fir
Add a semicolon to that line.
thanks!
I've also noticed that the arrows at the end of the code must be from left to right
now it works fine :-)
Hi John:
I noticed you are running Quartus II 4.2 web edition. If you are just playing with Quartus, it's probably fine, but if you are planning on working on a new design, I highly recommend you download the latest version. The timing tools have changed significantly, it also supports the latest devices, which 4.2 wont.
Pete
Continuing with Pete's point, it's best to use the latest version of Quartus even if you are just doing a learning exercise.
Pete mentioned that "the timing tools have changed significantly." If you are a new Quartus user, you might as well learn to use TimeQuest and not bother with the Classic Timing Analyzer.
--- Quote Start ---
--- Quote End ---
That problem was fixed sometime between versions 4.2 and 7.2 (another reason to use the latest version). The 7.2 messages:
--- Quote Start ---
Info: Version 7.2 Build 151 09/26/2007 SJ Full Version
Info: Processing started: Tue Oct 30 15:56:51 2007
Info: Command: quartus_map --lower_priority --read_settings_files=on --write_settings_files=off verilog_warning_for_vhdl_design -c verilog_warning_for_vhdl_design
Info: Found 2 design units, including 1 entities, in source file adder.vhd
Info: Found design unit 1: adder-arc
Info: Found entity 1: adder
Error (10500): VHDL syntax error at fir.vhd(14) near text "architecture"; expecting ";"
Error (10500): VHDL syntax error at fir.vhd(16) near text "component"; expecting "end", or "begin", or a declaration statement
Error (10500): VHDL syntax error at fir.vhd(27) near text ":="; expecting ")", or ","
Error (10396): VHDL syntax error at fir.vhd(33): name used in construct must match previously specified name "fir"
Error (10523): Ignored construct fir at fir.vhd(4) due to previous errors
Error: Quartus II Analysis & Synthesis was unsuccessful. 5 errors, 0 warnings
Info: Allocated 155 megabytes of memory during processing
Error: Processing ended: Tue Oct 30 15:56:53 2007
Error: Elapsed time: 00:00:02
--- Quote End ---
