I'm using modelsim-Altera to make a gate-level simulation of an own ifft core, the target platform is an Stratix II FPGA.
When i select the analog waveform display format for a signed 16 bits port corresponding to a Synthesized sine wave , i get in the picture some peaks (like glitches) that take random and big values, however the sine wave has an amplitude of 64. The basic sine shape looks well. I notice that this peaks appear before the t_su completion. I tried with a RTL simulation, however the ram memories in design (m4k's and m512's) don't work well. There is a way to define a trigger source, Such that the analog waveform display is sampled after every rising edge of a clock signal?. Why the ram memories don't work in the RTL-simulation? I appreciate any help with this. Regards, Alex ParradoLink Copied
I think, the glitches in analog waveforms are corresponding to glitches in the displayed signal. Resampling the data before displaying them should help.
I performed RTL and gate-level simulations of designs with RAM blocks and wasn't aware of any ModelSim issues in this regard. What do you mean with don't work well?- Mark as New
i run the rtl-level simulation and de data before the memories ports is correct, after of them the data is wrong. modelsim shows a warning referring to the clock edge in that the reading is made.
haw can i do the resampling using modelsim?
I didn't exactly understand what's the timing problem releated to memory operation. But if the data is stable a the clock edge, I meant you can simply add a register in your simulation, clocked from the said clock.
The user manual tells about an option to sample signals at a clock edge, but I'm not sure if it applies only to the list window or also to the waveform window.
