hello everyone,
I am using altera DE2 cyclon II and quartusII 9.1 . I work on video frames and I need to store them in a two dimensional RAM. I wrote the code like this: module memory (iCLK, we, a, b, idata, odata); input iCLK; //input iRST; input we; input [639:0] a; input [1279:0]b; input [9:0] idata; output [9:0] odata; reg [9:0] memory [9:0][9:0]; integer j,k; always@(posedge iCLK) begin if (we) begin for(k = 0; k < 10; k = k +1) for(j = 0; j < 10; j = j + 1) memory[k][j] <= idata; end end assign odata = memory[a][b]; endmodule but the problem is, compiler says there is not enough pins. could any one help me? or have you another idea to do this. thanks.Link Copied
is this
module memory (iCLK, we, a, b, idata, odata); your top level ? if yes then you will need 1 pin for iCLK 1 pin for we 640 pins for a 1280 pins for b 10 pins for idata 10 pins for odata this is a summ of 1942 io pins only for this module and not taken into account the pins for power supply. at least much more than the biggest part i knew.- Mark as New
you are exactly right. this is just a part of a project.
I try to minimize the size of ram and writing on the old values. ı hope it works- Mark as New
Angela,
Is your device just working as a RAM? Does 'a' and 'b' refer to address of the RAM? If yes then, do you really need such a high width for your RAM?- Mark as New
I think to minimize your ram is not your only problem. I´m quiet shure that you can minimize your code to odata = idata as far as you have written it and that´s not what it should do I think. So why don´t you use some of Altera´s altsyncram to build your array. I think that´s the easiest way to manage your problem.
There is another issue :
--- Quote Start --- input [639:0] a; input [1279:0]b; reg [9:0] memory [9:0][9:0]; assign odata = memory[a][b]; --- Quote End --- as you can see be inserting the definitions for a and b you will get --- Quote Start --- reg [9:0] memory [9:0][9:0]; assign odata = memory[639:0][1279:0]; --- Quote End --- the read access to the memory uses a 640x1280 array, but the memory is instantiated only as a 10x10 array.
