hi
There are some SDK (pcie385n_a7 and pcie385_d5). But when I execute the helloworld program , I can not execute successfully. I tried to execute other program , the same situation happened (ERROR: CL_INVALID_BINARY) How to solve this problem ? """"""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""" This shouldn't happen: 6ee4c670-6bf3-4db4-872e-fb383606a7e3 Error: dd00cd6b-c947-40ff-95a0-41bcf30dcc31 device_id = 0x4 Unrecognised card type, so can't instantiate appropriate Flash/UFM/UCD classes! Querying platform for info: ========================== CL_PLATFORM_NAME = Altera SDK for OpenCL CL_PLATFORM_VENDOR = Altera Corporation CL_PLATFORM_VERSION = OpenCL 1.0 Altera SDK for OpenCL, Version 14.0 Querying device for info: ======================== CL_DEVICE_NAME = pcie385n_d5 : Unknown CL_DEVICE_VENDOR = Nallatech ltd CL_DEVICE_VENDOR_ID = 4466 CL_DEVICE_VERSION = OpenCL 1.0 Altera SDK for OpenCL, Version 14.0 CL_DRIVER_VERSION = 14.0 CL_DEVICE_ADDRESS_BITS = 64 CL_DEVICE_AVAILABLE = true CL_DEVICE_ENDIAN_LITTLE = true CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768 CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0 CL_DEVICE_GLOBAL_MEM_SIZE = 4294967296 CL_DEVICE_IMAGE_SUPPORT = false CL_DEVICE_LOCAL_MEM_SIZE = 16384 CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000 CL_DEVICE_MAX_COMPUTE_UNITS = 1 CL_DEVICE_MAX_CONSTANT_ARGS = 8 CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 1073741824 CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3 CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 8192 CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024 CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4 CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2 CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0 Command queue out of order? = false Command queue profiling enabled? = true Using AOCX: hello_world.aocx ERROR: CL_INVALID_BINARY Location: ../common/src/AOCL_Utils.cpp:391 Failed to create program with binary """"Link Copied
The BSP version that was used to create the file in flash must match the BSP version that you have installed on the host. You need to update the flash with the base.aocx file for the BSP you have installed on your host. Because you can't use the software utilities at this point (because of the firmware mismatch), you will need to update the flash via JTAG. Power the host down Connect USB-Blaster REV-C to 385 board and host https://www.youtube.com/watch?v=mggkjwetwsq https://www.youtube.com/watch?v=fvvwpibwimo Connect the USB cable to the host Power up the host When in OS, browse to BSP location; for example: /opt/altera/15.0/hld/boards/nalla_pcie/hardware/p385_hpc_d5 Run the perl script to update the flash: "perl flash_recovery.pl base.aocx" This will take around 20min, when finished power down the host (a reboot will not be enough) Power up the host When in OS, run "aocl diagnose acl0" to verify everything is OK Thanks- Mark as New
hi
I have done the step ( Connect the USB cable to the host) lspci (Unassigned class [ff00]: Altera Corporation Device ab00) But I entered the directory : /home/user/altera/14.0/hld/boards/nalla_pcie/hardware/p385_hpc_d5 and ran the perl flash_recovery.pl base.aocx The error messages showed that """""""""""""""" Error (209062): Flash Loader IP not loaded on device 0 Error (209053): Unexpected error in JTAG server -- error code 5 Error (209053): Unexpected error in JTAG server -- error code 89 Error (209012): Operation failed Info (209061): Ended Programmer operation at Fri Jul 24 09:38:18 2015 Error: Quartus II 64-Bit Programmer was unsuccessful. 4 errors, 0 warnings Error: Peak virtual memory: 1681 megabytes Error: Processing ended: Fri Jul 24 09:38:18 2015 Error: Elapsed time: 00:00:05 Error: Total CPU time (on all processors): 00:00:05 Error: quartus_cpf failed at flash_recovery.pl line 92. """""""""""""""" How to solve the problem ?- Mark as New
When running the flash_recovery script, the board must be powered and connected to the JTAG programming cable as shown in the doc linked below. You must run the script from the computer the JTAG programming cable is plugged into with the USB cable. The board must be powered.
Also, please make sure the USB config file is correctly setup: https://www.altera.com/support/support-resources/download/drivers/dri-usb_b-lnx.html You might also need to run as root. http://www.alteraforum.com/forum/attachment.php?attachmentid=8908&d=1400634781- Mark as New
Hi boyihuang,
Are you now up and running? Did the above solve your issue? G- Mark as New
Thank for your help
I could run the example successfully : ) But I downloaded the examples(channelizer and Monte Carlo) , I could not complie the example successfully. It always showed " internal complie error " The board I used is nallatech pcie385N Tnanks- Mark as New
Great news on getting things running!
Regarding your compilation issue: to get additional info about your "internal compile error", go to the compilation kernel folder and look into the <kernel>.log and the quartus_sh_compile.log you will find details about the issue.
