need helps in coding...
hi i'm using an ultrasonic sensor to measure distance which produces PWM output, the pwm output is 147us/inch. i want to implement it in de2 board.
i'm using 50MHz input clock from de2 board and the input from the sensor is 147us/inch. so 147us / 20ns = 7350 counts per inch. i'm already tried to do some coding to read the sensors output, i'm planning to use the sensor to measure distance up to 8 inch. so basically i just count the counter to 7350 to 1 inch and continue counting to 2 inch and so on. this is the coding,am i doing it right or is it violates the way to reads pwm? when i compile it using quartus there are no errors but when i use the sensor nothing happens.. anyone has any suggestion.?
thank you,
regards,
faizul
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity maxsonar_pwm_signal_decoder is
Port ( clk : in STD_LOGIC;
reset : in STD_LOGIC;
maxsonar_pwm : in STD_LOGIC;
y : out std_logic_vector(0 to 7);
led : out std_logic;
pwm_distance : out std_logic_vector(2 downto 0));
end maxsonar_pwm_signal_decoder;
architecture Behavioral of maxsonar_pwm_signal_decoder is
signal pwm_inches : std_logic_vector(2 downto 0);
signal pwm_distance_i : std_logic_vector(2 downto 0);
begin
pwm_distance <= pwm_distance_i;
process(clk)
variable pwm_count : integer range 0 to 60000;
begin
if reset = '1' then
pwm_count := 0;
pwm_distance_i <= "000";
elsif rising_edge(clk) then
if maxsonar_pwm = '1' then
if pwm_count = 7350 then
pwm_inches <= "001";
end if;
if pwm_count = 14700 then
pwm_inches <= "010";
end if;
if pwm_count = 22050 then
pwm_inches <= "011";
end if;
if pwm_count = 29400 then
pwm_inches <= "100";
end if;
if pwm_count = 36750 then
pwm_inches <= "101";
end if;
if pwm_count = 44100 then
pwm_inches <= "110";
end if;
if pwm_count = 51450 then
pwm_inches <= "111";
else
pwm_count := pwm_count + 1;
end if;
else
if (pwm_inches > "000") then
pwm_distance_i <= pwm_inches;
end if;
pwm_count := 0;
pwm_inches <= "000";
end if;
end if;
end process;
process(pwm_inches )
begin
case pwm_inches is
when "000"=>
y<="10000000";
when "001"=>
y<="01000000";
when "010"=>
y<="00100000";
when "011"=>
y<="00010000";
when "100"=>
y<="00001000";
when "101"=>
y<="00000100";
when "110"=>
y<="10000010";
when "111"=>
y<="00000001";
when others=>
y<="00000000";
led <= '1';
end case;
end process;
end Behavioral;
When you have a look at this section:else if (pwm_inches > "000") then pwm_distance_i <= pwm_inches; end if; pwm_count := 0; pwm_inches <= "000"; end if;The pwm_inches is reset at 000 as soon as the PWM pulse ends. You probably won't see anything on the output because of that. I think that your second process should use the pwm_distance_i signal instead, that should keep the value of the measured distance after the PWM pulse ends:process(pwm_distance_i ) begin case pwm_distance_i is when "000"=>And also in that last process, you assign led to 1 in the others section, but never to 0. If you want the led signal to be 0 when you have a valid measured distance, you can assign a default value before the case:process(pwm_distance_i ) begin led <= '0'; case pwm_distance_i is when "000"=>
thanks for your reply, i'm already made the correction, but still there are nothing happens to the led when i connect the sensor output to de2 board. what i concern is, am i doing the right way for reading pwm output from the sensor. this is the datasheet for the sensor i used. http://maxbotix.com/documents/mb1010_datasheet.pdf
there are 3 type of output which is pwm, serial output and analog, but i'm need to use the pwm output.
thanks,
regards,
faizul
it looks right. I suggest to use Signaltap to check that the signal you are getting is what you expect and that the counter increments as it should.
