17252 Discussions
pin assignment in Quartus II
I am a beginner . How can we do pin assignment according to device?? How to import file ?which file has to import? what is pin planner?
Anyone please help me .
Thank you
If you're new to this I recommend you use the Pin Planner tool built into Quartus.
If you haven't already, run the 'Analysis & Synthesis' on your project.
Select 'Assignments' -> 'Pin Planner'.
On the left will be a list of all your top level signal names. Double click the 'Location' cell next to each signal. This will allow you to assign the pin you want.
Cheers,
Alex
thanks sir... Can I get one more Help? I need to get the pin out details of Ep2s60f672c3n as to assign At location box. C an u please suggest me any link for that?
Thankyou
Thanks alot...
In a similar vein, I am trying to understand what ends up in the Assignment Editor after a pin assignment. In my case, I'm using Quartus II 13.1 Web Edition with the DE0-Nano. In the Pin Planner, I assigned the 50MHz clock, resulting in the following:
Node Name: CLK_50
Direction: Input
In the Assignment Editor, this shows up as:
Status: ? 'To' name unrecognized
To: CLK_50 (with a question mark icon
Assignment Name: Location
Value: PIN_R8
Entity: (grayed out
However, there's another option in the Assignment Editor for "Assignment Name": external pin connection. In this case, I can enter the following:
Status: Ok
To: CLK_50
Assignment Name: External Pin Connection
Value: R8
Entity: (my top-level entity name
So which is more correct? It certainly seems like the "External Pin Connection" would be the most accurate, but I cannot seem to find any documentation about when that should be used. And it doesn't quite seem to be associated to the Pin Planner. So now I am just confused.
hi,
http://www.altera.com/literature/manual/mnl_nios2_board_stratixii_2s60_rohs.pdf . can I refer above link for ep2s60f672c3n pin assignment? http://www.altera.com/literature/dp/stratix2/ep2s60.pdf I noticed this link but exact pin for LED and all not specified in it detail... please reply
Thank you
