17267 Discussions
pleez,, URGENT!! about loops in verilog?
Hey all;
I'm trien to write a loop in verilog to initialize all the entries in an array of 128 to a value of zero,
and I'm having the following error:
procedural continuous assignment to register is not supported
here is my code ::
// Instruction Memory
module imem(clk, reset, wr_enable,fetch_enable, mem_out, address, mem_in);
input clk;
input reset;
input wr_enable;
input fetch_enable; // this will control startin or stopin running stored commands
input [4:0] address;
output [31:0]mem_out;
input [31:0]mem_in;
reg [31 :0]mem_out;
reg [31 :0]array_reg[127:0]; //can save 128 instruction
integer i;
initial
while(i< 128)
begin
assign i = i+1;
mem_out[i]<= 32'hfffff;
end
always @(posedge clk)
begin
if(fetch_enable)
begin
if (reset)
begin
mem_out <= 32'd0;
end
else
if(!wr_enable)
begin
mem_out <= array_reg[address];
end
else
array_reg[address] <= mem_in;
end
end
endmodule
thaanks in advance :)
I think in general it's not a good idea to try to synthesize loops like the one you have created. If you are wondering why, try to think of how your code could be converted into hardware.
Also, don't use "initial" blocks when synthesizing, only when testbenching. Whatever you want to be done initially should be triggered by the reset or done when coming out of reset.
Seeing that you are looking to create 512 bytes of memory, you could just specify a memory block in the mega wizard and instantiate it in your code.
Just for kicks though, you could create a counter which selects the which register to write the initial value. Then, in an always block triggered by both the posedge of clock and negedge of reset, you could: 1) take the counter out of reset when the reset goes high, 2)on each clock pulse write to the register who's index is the counter value, 3) when the counter has passed the last register, put the counter back into reset and set a done flag so that you can get on with your other logic.
I would also recommend that you go over some more unrelated example designs in Verilog.
Let me know if it works.
Andrew
--- Quote Start ---
Hey all;
here is my code ::
input clk;
input reset;
input wr_enable;
input [31:0]mem_in;
reg [31 :0]mem_out;
integer i;
initial
while(i< 128)
begin
assign i = i+1;
mem_out<= 32'hfffff;
end
begin
if(fetch_enable)
begin
if (reset)
begin
mem_out <= 32'd0;
end
else
if(!wr_enable)
begin
end
else
end
end
endmodule
--- quote end ---
hi,
you are using the assign statement with an integer. that's not allowed.
assign i = i+1 --> change to i = i + 1;
do really want to initialize "mem_out". "mem_out" is already set to a defined state
with the reset signal.
in case you would like to init your ram "array_reg" change your code to :
integer i;
integer p;
initial
begin
i = i+1;
p = 128;
for (i=0; i<p; i=i+1)
array_reg<= 32'hffffffff;
end
Using "while" is not recommended.
Have a look into the "db" folder. You will find a so-called <>.mif file. Look into the file and you could see the init values for the ram.
Kind regards
GPK
