I am using an ALTIOBUF megafunction in my design. it works as a LVDS tx buf.
Its outputs(dataout and dataout_b) stay at z when being simulated. in the generated file(lvds_tx_buf.v) devoe of cyclone_iii_obuf is connected to 0. --------------------------------------------- cycloneiii_io_obuf obufa_0 ( .i(wire_obufa_i[0:0]), .o(wire_obufa_o[0:0]), .obar(wire_obufa_obar[0:0]) `ifdef FORMAL_VERIFICATION `else // synopsys translate_off `endif , .oe(1'b1), .seriesterminationcontrol({16{1'b0}}) `ifdef FORMAL_VERIFICATION `else // synopsys translate_on `endif // synopsys translate_off , .devoe(1'b0) // synopsys translate_on ); defparam obufa_0.bus_hold = "false", obufa_0.open_drain_output = "false", obufa_0.lpm_type = "cycloneiii_io_obuf"; --------------------------------------------- In module cycloneiii_io_obuf in cycloneiii_atoms.v --------------------------------------------- assign tmp1 = (devoe == 1'b1) ? tmp : 1'bz; assign tmp1_bar = (devoe == 1'b1) ? tmp_bar : 1'bz; pmos (o, tmp1, 'b0); pmos (obar, tmp1_bar, 'b0); --------------------------------------------- i don't know if i have explained the problem exactly. how to solve the problem?Link Copied
