17254 Discussions
problem installing 10.0_modelsim_ase_windows
Hi all,
I'm having problems with installing 10.0_modelsim. I have tryed the installation tool where it fetches directly from altera and also tryed installing the stand alone 10.0_modelsim_ase_windows.exe file. I have already installed the 10.0 nios2eds and 10.0 quartus, but when I go to start->Altera->quartus the symlink starts looking for the programs...
Not sure if my system is compleatly ****ed or what is going on...
Just post if you are experiencing some problems with installing..
Cheers
Stefan
btw I run Windows XP
Also if I now go into "Add or Remove Programs" The Quartus or Nios2des do not show up there even if they installed successfully... If I try lunching them I get missing shortcut...
Cheers
Stefan
I now re-installed nios, modelsim, and quartus 91.sp2 and no problem. Then I removed them all with ControlPanle->Add or Remove Programs. Did a restart. Then tryed to install inn the following order:
10.0_quartus_free_windows.exe "innstalled passed"
10.0_nios2eds_windows.exe "installed passed"
10.0_modelsim_ase_windows.exe "installed failed"
The note I get with the Installation Failed is:
ModelSim-Altera Starter Edition (Free) installation failed.
Incomplete installation File 'c:altera\10.0\modelsim_ase\..
\modelsim_ase/win32aloem/instanceguid.txt' does not exist.
It is a bit supprising to see the switching of \ and / in the path... but this is how the error looks like..
now if I try starting quartus, modelsim or nios2eds then it starts browsing for missing shortcut...
Can someone report that they had no problem installing the new v10.0 on Windows XP. If so then there is something wrong with my PC and I will have to go through the trouble of installing a clean Win XP on it again...
Cheers
Stefan
I came here following your link.
I also have a similar problem.
I've Window Vista and previously installed QuartusII 9.0 and 9.1sp1.
The installation seems ok but the Quartus executable is not present.
Any hint?
I do have the same problem on a 64bit windows xp machine, on a 32bit machine with same operation system in works fine...
I now copied the altera/10.0 dir from the 32bit machine to the 64bit machine and everthing seams to work...
PS: i have the subscription edition
This is not the same for me.
The version I'm trying to install is the web free edition.
I wonder if the software is the same.
I'm trying to dowload the installation file again.
Maybe Altera provided a minor change to it...
I used the web edition, tried both the downloaded file and the web installer on Windows XP 32 bits, but no luck. The Quartus seemed to install fine. But reported missing ling when I lunched it from Start->altera->Quartus :(
Also it does not appear in the controle panel add/remove programs...
No modifications to the downloaded executable from yesterday.
Always the same problem.
Then I tried changing the installation path from:
c:\altera\10.0 to c:\altera\10
No result
Then I tried allowing altera "to retrieve information"
No result
Now I'm trying both...
no result
Ill try on a different computer...
On a machine with XP installed the installation was fine..
I just notice Altera released a new version of their Windows installers. I have created a new thread for this.
altera installer v10.0 rev2 released (http://www.alteraforum.com/forum/showthread.php?t=24762)
