problem with HSMC
Hello.
I use Cyclone III starter kit and I program with vhdl .I don't use block symbol file.
I want to use pin of HSMC rx and tx(HSMC_TX_p4-HSMC_RX_p11) like general purpose data(HSMC_D0-D19).
I will wait for advice.
Just assign your signals to the correct FPGA pins in the pin planner.
I am very embarrasses to very few number of general I/O.
I am wonder why Altera HSMC specification has so much rx tx pin.
I do not think 12 set of LVDS connection is over spec.
My usage is general control, then I need more general I/O.
In this case, if I use three set of Cyclone III starter board, and One is host and other two are controller and communicate by LVDS,
I can seem to solve many control task using general I/O and USB communination with PC.
Is that right ?
rx and tx are just conventions, you can use them in any direction you want. But you need to keep the pairs together if you use them as LVDS (i.e. HSMC_TX_p4 and HSMC_TX_n4 together, but not HSMC_TX_p4 with HSMC_RX_p11).
For the pins that you use as general I/O if you don't use LVDS you can use any pin as you want, as input or output.
If you have a lot of data to move from/to the PC, it may be easier to use the Ethernet port. The embedded USB Blaster only allow communication through JTAG, and you would need to use a virtual JTAG component or the JTAG uart.
Thank you very much your advise.
I connected output pin using HSMC_TX_p4 and HSMC_TX_n4.
I use input data port for HSMC_D*. My program works.
But I connected output pin using HSMC_TX_p4 and HSMC_TX_n4.
And also I connected input pin assignment (LVTTL,3.3V standard) for
HSMC_RX_n4 and HSMC_RX_P4.
My program does not work.
We set port section as follows.
rx_in : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
rx_out : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);
tx_in : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
tx_out : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);
I am appreciate, if you suggest further configuration.
I don't see any problem with you port section, even if you could use STD_LOGIC instead than STD_LOGIC_VECTOR(0 DOWNTO 0) for a single bit, but this doesn't change anything to the design.
Try to put signaltap probes on your signals to find out what is going on.
