17255 Discussions
problem with sopc builder
i m learning
Introduction to the Altera SOPC Builder
Using VHDL Design,working as per the instruction but on
Figure 18. Instantiating the Nios II system.(file attached)
it is written
−− Instantiate the Nios II system entity generated by the SOPC Builder
what i should write there.
--- Quote Start ---
--- Quote End ---
Nothing, just copy and paste that code on a new VHDL file, call it "lights.vhd" and makes it the top level entity. (project->Set as top level entity). This example uses just clock and reset signals, green leds and switches.
the compilation was successful with warning but i m getting message like
Info: SRAM Object File F:/sopc_builder/lights_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0xBCEC
when i open Tool----->programmer
Just don't click on dialog button after programming, leave it as is. Then, begin with software part with Nios II IDE.
