17268 Discussions
problems with real data type conversion to std_logic_vector
Hi, I'm doing an discrete PID controller, based on FPGA's, but I wanna do it using floating point maths, the first block I was doing was an integrator, but I got an issue, the generic parameters of my project are real values, and the port of the megawizard IP is an std_logic_vector (31 downto 0), i don't know how to cast from real to std_logic_vector(31 downto 0), here my code:
Library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
--use IEEE.STD_LOGIC_ARITH.ALL;
--use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.math_real.all;
use IEEE.numeric_std.all;
entity bloque_integrador is
generic
sample_time : real :=1.0e-3;
gain : real :=1.0
port
clk_50MHz : in std_logic:='0';
clk_sys : in std_logic :='0';
rst : in std_logic:='0';
int_in : in std_logic_vector(31 downto 0):=X"00000000";
int_out : out std_logic_vector(31 downto 0)
end entity bloque_integrador;
architecture structural of bloque_integrador is
-------señales de conexion internas al modulo-----
signal int_in_reg : std_logic_vector(31 downto 0);
signal int_in_reg_amp : std_logic_vector(31 downto 0);
signal int_out_reg : std_logic_vector(31 downto 0);
signal acumulador : std_logic_vector(31 downto 0);
signal clk_sys_n : std_logic;
-------constantes del sistema-----------------
constant factor_amplificacion : real:=(sample_time*gain);
signal factor_amplificacion_vector : std_logic_vector(31 downto 0);
-----------------componente multiplicador-------------
COMPONENT amplifier_altfp_mult_nvo IS
PORT
aclr : IN STD_LOGIC := '0';
clk_en : IN STD_LOGIC := '1';
clock : IN STD_LOGIC;
dataa : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
datab : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
END COMPONENT amplifier_altfp_mult_nvo;
----------------componente sumador---------------
COMPONENT sumador_altfp_add_sub_t8k
PORT (
aclr : IN STD_LOGIC ;
clk_en : IN STD_LOGIC ;
clock : IN STD_LOGIC ;
END COMPONENT;
begin
-------------------declaraciones adicionales------------
factor_amplificacion_vector<=to_stdlogicvector(to_bitvector(factor_amplificacion));
clk_sys_n<=not(clk_sys);
--------------declaracion del registro de entrada------------
reg_in: process(clk_sys, rst, int_in, int_in_reg)
begin
if rst='1' then int_in_reg<=(others=>'0');
elsif( clk_sys'event and clk_sys='1') then
int_in_reg<=int_in;
end if;
end process reg_in;
--------------declaracion del registro de salida------------
reg_out: process(clk_sys, rst,acumulador, int_out_reg)
begin
if rst='1' then int_out_reg<=(others=>'0');
int_out_reg<=acumulador;
end if;
end process reg_out;
----------------componente multiplicador----------------
multiplicador: amplifier_altfp_mult_nvo
PORT MAP
aclr => rst,
clk_en => clk_sys_n,
clock => clk_50MHz,
dataa => factor_amplificacion,
datab => int_in_reg,
result => int_in_reg_amp
suma:sumador_altfp_add_sub_t8k
PORT map (
aclr =>rst,
clock => clk_50MHz,
datab => int_in_reg_amp,
dataa => int_out_reg,
result => acumulador
int_out <=int_out_reg;
end architecture structural;
thank you for read, I'll apreciate your help.
the IEEE floating point package that became a standard with VHDL 2008 will have the conversion function you need. For a '93 compatible version you can compile into your project, see here: http://www.vhdl.org/fphdl/
Also, when you use this, factor_amplificacion_vector should be declared constant, because it never changes.
thank you, I'm downloading the libraries, you have been so kind.
--- Quote Start ---
--- Quote End ---
It looks like the OP intends unsigned integer arithmetic, the real to unsigned conversion can be done without additional libraries.
