17267 Discussions
programmer doesn't see usb blaster
On a new netbook (Samsung NC10 with XP home, sp3) I installed the quartus II version 8.1 programmer. I also installed drivers for the usb blaster. The programmer keeps saying: No Hardware at hardware setup.
I checked everything more than once. No other FTDI devices. The setup is the same as on my desktop machine (XP pro, SP2). And there it works.
usbblstr.sys in ..../system32/drivers
usbblstr32.dll in ..../system32
usbblstrlang.dll in ..../system32
usbblstrui.dll in ..../system32
Should there be a referecence to usbblstr in my register? Because there isn't.
How does the USB Blaster show in Control Panel/Hardware Tab?
In the hardware tab it is shown as "Altera USB-Blaster" under "USB-controllers"
I finally found the problem.
After trying to "add hardware" at the "hardware setup" in the programmer, I got the message “Attempted to access JTAG server -- internal error code 82 occurred”.
I ignored it all the time, but after an internet search, someone at this forum in an old thread, suggested to switch of the firewall software (thanks Embedos).
So I did. The error message disappeared en the USB blaster showed up on the "add hardware list". Ready to be chosen. YES.
So to be able to use the USB-blaster, you need to have a JTAG server. Usually this is the local machine. To find this server (my own PC!!!) I had switch off the firewall software. It's time to finetune this software.
--- Quote Start ---
--- Quote End ---
If by "software" you mean Windows and if by "fine tune" you mean jettison, then I'm in 100% agreement :-)
I was wondering, how does Quartus II perform on the netbook?
Hi ,
Thank you very much std_logic_vector, it works for me. After I had all kind of issues installing in Windows 7 the USB Blaster, :DI went to this link http://www.altera.com/download/drivers/dri-index.html
this is a page about Cable & Adapter Drivers Information. I choose the one taht suits me, it leads you to a page with the instructions you need.
Then I had another error "attempted to access jtag server -- internal code 82 occurred" which I solve thanks to your post.
It worked for me, I hope il will be the same for the beginner like me!!!
I have a Samsung netbook running win7-starter. I read several threads and tried firewall settings and different versions of quartus programmer -- and had several frustrating days and many hours of lost work. One common thread seems to be the compatibility of windows & programmer versions. So ...
I tried different versions, in this order, 11, 10.1, 7.1, 7.2, 7.2sp3, 9.1.
All failed until version 9.1.
Now I turned the firewall back on (recommended settings in win7), and it still works.
Just thought I'd share this with you all. In this day where smart-phones are smarter than PCs from a few years ago, and millions of gadgets are running flawlessly everywhere, we still get stuck for days with junk like this.
Hello.
I was using Quartus II 13.0 vers before and successfully installed the USB Blaster. But the problem is it can't generate the .sof files since it was a trial version.
therefore I installed Quartus II 10.1 vers 64-bit that came along with the DE0 Nano box. And now the USB Blaster does not get detected anymore. It was installed on the device manager showing 'Altera USB-Blaster' but the Programmer doesn't detect it at all.
Can anyone help me? I would be grateful if anyone would at least reply to me.
Having the same problem as the last poster. Tried the firewall setting and reinstalled blaster several times on different usb ports. Any help???
--- Quote Start ---
--- Quote End ---
In my case, I actually solve my own problem regarding the usb blaster. Previously I mentioned that I installed quartus 13 and 10, and the usb blaster doesnt get detected anymore. It turns out the culprit was the quartus 10. I dont know how or why, but after uninstalling the quartus 10, the usb blaster get detected again. Hooray. Since i still can't get the .sof file, i finally decided that to get quartus 13 web version to get .sof file. Thankfully the usb blaster still get detected even after installing another version of quartus. I think to be safe just use the quartus 13 web version but it still does have a minor problem so i decided to keep the quartus 13 n the web version. Haha.
I'm a newbies. Sorry if my post doesn't help you.
Thanks for the reply, I had the same issue with there being old instances of Quartus left behind. I took the bin folder from the first instance and pasted in the newer instance. I also manually initiated Jtag server. It worked for the time being but I'll tell if it sticks once I restart my computer
Hi all,
I had this problem now, everything had been working fine, but after PC restart, my programmer stopped to see USB Blaster.
I have tried everything you have mentioned here. Nothing helped.
1) Reinstall drivers - DIDN'T HELP
2) Reprogram EEPROM - DIDN'T HELP
3) Turn off firewall - DIDN'T HELP
4) Clean regs and temp files - DIDN'T HELP
My solution was restart of JTAG server.
1) Run CMD as administrator
2) go to \quartus\bin\ (if you are running 64 bit OS, go to bin64)
3) execute:>jtagserver --uninstall
4) execute:>jtagserver --install
5) execute:>jtagserver --stop
6) execute:>jtagserver --start
All these commands may help you to unstuck your JTAG recognition.
Good luck! I hope it will help someone. :)
