pulse counting
I'd like to code a pulse counter : after X pulses from a signal, another signal toggles (I choose 4 in my example).
I wrote this piece of code, and the behavior is not as i expected.
http://www.alteraforum.com/forum/attachment.php?attachmentid=13204&stc=1
pulse_gen : process (clk) -- square generation from a given frequency begin if rising_edge (clk) then if reset = '0' then pulse_counter <= (others => '0'); pulse_tick <= '0'; pulse_toggle4 <= '0'; else if ((en_in <= '1')) then if pulse_counter = max_count then pulse_counter <= (others => '0'); pulse_tick <= not pulse_tick; counter_dir <= counter_dir +1; if ((counter_dir = "00001000")) then -- 8 for 4 pulses counter_dir <= (others => '0') ; pulse_toggle4 <= not pulse_toggle4 ; end if ; else pulse_counter <= pulse_counter + 1; end if; else pulse_counter <= (others => '0'); pulse_tick <= '0'; end if; end if; end if; end process pulse_gen; pulse <= pulse_tick; toggle4 <= pulse_toggle4;
I would be grateful if you could have a look
Are you sure this is the correct code. The toggle signal is falling on the falling edge of the clock, not the rising.
Can you post all of the code AND testbench?
Code :
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity pulsegen is generic ( pulse_to_count : unsigned(7 downto 0) := "00001000" ); port( clk : in std_logic; reset : in std_logic; ratio_freq : in unsigned(19 downto 0); en_in : in std_logic; pulse : out std_logic; toggle_pulse : out std_logic ); end pulsegen ; architecture arch of pulsegen is signal pulse_tick : std_logic :='0'; signal pulse_dir : std_logic :='0'; signal pulse_counter : unsigned(19 downto 0) := (others => '0'); signal counter_dir : unsigned(7 downto 0) := (others => '0'); begin pulse <= pulse_tick; toggle_pulse <= pulse_dir; pulsegen : process (clk) begin if rising_edge (clk) then if reset = '0' then pulse_counter <= (others => '0'); pulse_tick <= '0'; pulse_dir <= '0'; else if (en_in <= '1') then if pulse_counter = ratio_freq then pulse_counter <= (others => '0'); pulse_tick <= not pulse_tick; counter_dir <= counter_dir +1; if (counter_dir = pulse_to_count) then counter_dir <= (others => '0') ; pulse_dir <= not pulse_dir ; end if ; else pulse_counter <= pulse_counter + 1; end if; else pulse_counter <= (others => '0'); pulse_tick <= '0'; end if; end if; end if; end process pulsegen; end arch;
Test Bench :
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity tb is end tb; architecture behavior of tb is component pulsegen generic ( pulse_to_count : unsigned(7 downto 0) := "00001000" ); port( clk : in std_logic; reset : in std_logic; ratio_freq : in unsigned(19 downto 0); en_in : in std_logic; pulse : out std_logic; toggle_pulse : out std_logic ); end component; signal clk : std_logic := '0'; signal reset : std_logic := '0'; signal en_in : std_logic := '0'; signal pulse : std_logic := '0'; signal toggle_pulse : std_logic := '0'; signal ratio_freq : unsigned(19 downto 0) := "00000000000011111010"; --determines pulse output frequency constant pulse_to_count : unsigned(7 downto 0) := "00001000"; --toggles every 8 pulses from pulse output constant clk_period : time := 20 ns; --50MHz begin uut: pulsegen generic map(pulse_to_count=>pulse_to_count) port map(clk=>clk, reset=>reset,ratio_freq =>ratio_freq, en_in=>en_in,pulse=>pulse,toggle_pulse=>toggle_pulse); clk_process : process begin clk <= '0'; wait for clk_period/2; clk <= '1'; wait for clk_period/2; end process; stim_rx_proc: process begin wait for 100 ns; reset <= '1'; wait for 200 ns; en_in <= '1'; wait; end process; end;
If you use my code and TB you'll see there is something wrong. I'd like to have the "toggle_pulse" toggling every 4 pulses from "pulse".
Then just do a rising edge detection circuit on the pulse, and count 4 of them.
Rising edge detect compars the current value with the last value:
process(clk) begin if rising_edge(clk) then pulse_r <= pulse; if pulse_r = '0' and pulse = '1' then toggle_cnt <= toggle_cnt + 1; end if; if toggle_cnt = 3 then toggle_cnt <= 0; toggle <= not toggle; end if; end if; end process;
Ok, thank you ! :), I didn't know rising edge on an other signal than a clock was a good practice
--- Quote Start ---
--- Quote End ---
You're not using the rising edge function - you're building a rising edge detector. There is still only a single system clock.
What is the difference between your submitted code and using the rising edge function ?
--- Quote Start ---
--- Quote End ---
The rising edge function looks for the rising edge on an actual signal, like a clock (its not a logic circuit, just a langauge function).
An edge detect is a synchronous circuit that uses the input and a registered version of the input. Its a real logic circuit.
