qip generate
nirz
Im using the following command to generate ip:
quartus_ipgenerate --generate_ip_file --simulation=verilog --ip_file=/PATH/HBM2E_intel_noc_initiator_1.qip project_name
I get the following error:
File /PATH/HBM2E_intel_noc_initiator_1.qip is not a supported file type for IP Generation.
How can i generate it properly?
ShengN_Intel
The .qip is old file type. Please use either .qsys or .ip. If run this command quartus_ipgenerate --help=ip_file will get the followings:
Option: --ip_file=<>
Option to specify a Platform Designer IP file to be generated.
Examples:
     # Specify the Platform Designer IP file to be generated
    quartus_ipgenerate --generate_ip_file --ip_file=test.qsys test
    quartus_ipgenerate --generate_ip_file --ip_file=test.ip test
Sheng
ShengN_Intel
May I know do you have any further concern?
Sheng
