17255 Discussions
quartus 2 14.1 web : NO sof file
Hi zombot,
It seems like you might have missed out the warning messages in your post. By the way, probably you could double check if there is any issue with license setup?
check on the assemble report, it should show clearly why your sof file is not generated.
The sof file should be saved in "output_files" folder by default. Check on the output file directory in Settings/Compilation Process Settings
