quartus II libs
This might be a stupid question but, here goes.
How do I add a Library to the current quartus project, via the Library pane in settings?
If so does the top directory denote the library name?
example
lets say I have a directory structure as so;
/home/quartus/lib/A/B
if I place the path /home/quartus/A
Will 'A' be the Library name for vhdl 'library' purposes?
also will the contents of 'B' be added or ignored?
Oh, what libs are added by default and where are they located under altera/libraries?
thanxs
Thank you both so much...you both have really helped me with my understanding of Quartus.
I hope this thread helps others if they have the same mental block which I seem to have had.
Drforbin.
