17254 Discussions
quartus_cdb error on Linux
I'm getting the following error when calling quartus_cdb on a 64-bit Linux machine:
./quartus_cdb: error while loading shared libraries: libcomp_rec.so: cannot open shared object file: no such file or directory
I tried different parameters, different quartus versions (from 9.1sp2 to 11.1) - no luck, getting the same error
Calling quartus_cdb on my 64-bit Win-7 machine works fine.
Linux version is CentOS - Red Hat Enterprise Linux ES release 4 (Nahant Update 9)
Evgeni
Ok, resolved the issue myself.
I needed to specify LD_LIBRARY_PATH envvar, as follows:
export LD_LIBRARY_PATH=/opt/Altera/altera9.1sp2/quartus/linux64
Evgeni
