- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I'm observing an issue on Linux machines where quartus_fit process goes back and forth between Running and Sleep states. When this happens, the build is not progressing, and eventually I need to kill the process.
This happens intermittently on different Linux distributions (CentOS 5 and custom-built), and at least two Quartus revisions. There is sufficient amount of available memory, swap, and CPU in the system. It happens when I run one or several builds concurrently. I'm inclined to think that it's something to do with the server itself (but I've seen it on at least 3 very different servers). But I cannot rule out some obscure Quartus bug. Any ideas why this happens are appreciated. Thanks, Evgeni링크가 복사됨
6 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
that sounds really strange, i haven't seen or heard of that sort of behavior
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Those are quite "heavy" designs that take 8-12 hours to build, require at least 12GB of memory and use 4 CPUs. I'd say that in 90% of builds this problem doesn't happen.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
A quick update.
Those builds that were entering sleep state have actually completed. I let them run, and it took several times longer than usual. Instead of 8-12 hours, it took between 3 to 4 days. Opened an SR, and will see what Altera has to say about it.- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Another update.
After going back-and-forth with Altera for a couple of months, the conclusion is that the root cause of this problem is high utilization + high routing congestion of this design. Hope Quartus 12.x will make things better.
