17251 Discussions
quartus_fit was unexpectedly terminated by signal 9
BigHandsomeBee
I'm using Quartus Prime Pro 21.2.
When I synthesized a design on Stratix 10, I got an error:
Error(20549): Current module quartus_fit was unexpectedly terminated by signal 9. This may be because some system resource has been exhausted, or quartus_fit performed an illegal operation. You can view system resource requirements on the System and Software Requirements page of the Intel FPGA website (https://fpgasoftware.intel.com/requirements/).
I'm running the software on Ubuntu 20.04 with 32GB RAM.
Nurina
This error occurs due to exhaustive system resources usage. I believe your OS and memory is supported by Quartus. Does this happen to all the designs you try to compile? Can you attach a .qar file?
Nurina
Nurina
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
majinfly
Hi
I have the same problem as him。
I'm using Quartus Prime Pro 21.1 and the  device is Stratix 10, Error:
Error(20549): Current module quartus_fit was unexpectedly terminated by signal 6. This may be because some system resource has been exhausted, or quartus_fit performed an illegal operation. You can view system resource requirements on the System and Software Requirements page of the Intel FPGA website (https://fpgasoftware.intel.com/requirements/).
Archive project will also fail.
