Hi all,
# # Description I'm having a verify failure when programming Cyclone IV with quartus_jli only when running on USB 3.0. When I use the same computer with its USB 2.0 I don't have this issue. Output: ``` Info: Command: quartus_jli -c 1 -a program ./firmware/BrainsightNIRS.jam Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed! Device# 1 is EPCS64 erasing ASC device(s) in sector mode... programming ASC device(s) in sector mode... CRC verify ASC device(s) in sector mode... Device verify failure Exit code = 11... Device verify failure Error: Quartus Prime Jam Tools was unsuccessful. 0 errors, 0 warnings Error: Peak virtual memory: 189 megabytes Error: Processing ended: Fri Apr 21 11:39:21 2017 Error: Elapsed time: 00:01:35 Error: Total CPU time (on all processors): 00:00:19 ``` # # Environment * Ubuntu 16.04 * Quartus Altera Lite 16.0 * USB 3.0 (Computer) Connected to FX2 USB chip connected to FPGA Cylone IV Had anyone had a similar problem?Link Copied
Topic Options
