17268 Discussions
quartus prime standalone programmer windows 7 32 bit with MAX 10 support
Ben_Sg
Hi all,
I have a windows 7 32 bit.  But I need to program a MAX10 device.  My 13.1 quartus standalone programmer does not support MAX10.  Is there a way to install MAX10 device support into 13.1?
Which quartus version support windows 32 bit and support MAX10 programming?
I also tried 18.1 but it does not support windows 32 bit.  What else can I do so as to be able to program a MAX 10 device?
Thanks all for your advice.
Benedict
FvM
32-bit standalone programmer is latest available in QPS 18.1, hopefully it runs without problems under Windows 7.
Otherwise I suggest VirtualBox with 64 Bit Windows or Linux client.
Frank
Nurina
Hi Benedict,
Please note that the 32-bit Standalone Programmer for 18.1 is only supported in Quartus Standard Edition. There is no info on the Lite Edition.
OS Support information available on the readme.txt files for the corresponding Quartus version here: https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html
Nurina
Nurina
Do you have any updates?
Nurina
