17249 Discussions
"Advanced Data" in fitter report
Does someone know what "Advanced Data" section in fitter report (xxx.fit.rpt) shows? Do they contain information designer needs to know?
; Advanced Data - General ;
; Name ; Value ;
; Status Code ; 0 ;
; Desired User Slack ; 0 ;
; Fit Attempts ; 1 ;
What's the device ? This section doesn't show up in my fit reports (Stratix II and Stratix III)
Hi drdr6,
Thank you for your reply. I use Stratix III device. It seems this is shown in WinXp report not in Linux.
--- Quote Start ---
--- Quote End ---
Hi, this is information that is fed back to Altera if you have TalkBack enabled. There is nothing in it that the designer needs to know about; however, we have a policy of not sending back anything to Altera without the designer's knowledge. Therefore, we show what we're sending so you can be satisfied we're not sending back any sensitive data.
Other users are not seeing these panels as we do not generate them if TalkBack is disabled.
Cheers,
Adrian Ludwin
Altera
Hi aludwin,
I appreciate your answer. I fully understand it.
Thanks!
