17267 Discussions
"design does not contain any logic" But it has NAND logic and test bench!
Hi, everyone!
I have run into the problem that below for 3 days:
--- Quote Start ---
Error: Can't synthesize current design -- design does not contain any logic
--- Quote End ---
But the project included two files, one is testbench, and another is real source code.
Why does such problem (that there are no logic) happen ?
What setting or/and source code is wrong ?
Please tell me what perhaps is!
Thx!
--- Quote Start ---
module hogege;
reg sw1, sw2;
wire led;
nandtest nandtest1 (sw1, sw2, led);
initial
begin
sw1<= 0;
sw2 <= 0;
# 5 sw2 <= 1;
end
always begin
# 10 sw1 <= ~sw1;
end
always begin
# 16 sw2 <= ~sw2;
end
initial $monitor($stime, " sw1=%b sw2=%b led=%b", sw1, sw2, led);
endmodule
--- Quote End ---
--- Quote Start ---
//verilog1.v
`timescale 1ns / 1ps
module nandtest(input sw1, sw2, output led);
assign led = ~(sw1 & sw2); // I think this is logic circuit
endmodule
--- Quote End ---
The testbench code is ignored by the Quartus compiler, because it doens't support timed statements (#<timeinterval>). As a result, no logic is synthesized. Use ModelSim Altera Edition with HDL testbenches or Vector Waveform Files with Quartus Simulator.
Thanks a lot!
I could not know that from books...
Now, I boot Tool > Launch EDA Simulation Library Compiler ( because I can't make Vector wave form, Linux edition)
My PC has ModelSim from altera, and set the location where modelsim installed.
The dialog recognized(as ModelSim altera starter edition Oct 1 2009),
and Set Library language as Verilog. Device family is Max II.
But I just get such dialog any time....
--- Quote Start ---
The ModelSim-Altera software comes packaged with precompiled simulation libraries.
Do not compile simulation libraries if you are using the ModelSim-Altera software.
--- Quote End ---
What does it means? I just installed ModelSim, had not converted it at any.
Please tell me what should I do ?
Help please!Thx!
