17245 Discussions
"get_service_paths master" command fails in CMD
Hi!
Im new to Quartus II and I read the forum, but I cant still find the answer to my problem.
I have a need to run TCL scripts from Command Promt CMD (Windows Vista), In my script Im accessing the HW with command "get_service_paths master" and this Fails. I have already added "load_package systemconsole".
In CMD i run
C:\>quartus_sh -s
tcl> get_service_paths master
invalid command name "get_service_paths"
tcl>
In System-console It works...
% get_service_paths master
{/devices/5SGSMD5H(1|2|3)|5SGSMD5K1|..@1#USB-0/(link)/JTAG/(110:132 v1# 0)/phy_0/master}
Why this error?
Thanks for all your time
get_service_paths is a system console command and can only be run from System console. It won't work from the quartus shell.
The system console executable can be found at C:\altera\*\quartus\sopc_builder\bin\system-console.exe . Maybe you can run that from Windows command prompt
--- Quote Start ---
--- Quote End ---
I'm not sure that the Windows command prompt will work, since it probably does not have paths setup correctly.
System Console can be started from the command-line by using the Start menu to get to the "NIOS II Command Shell" (Cygwin shell) and typing system-console.
Cheers,
Dave
Actually it works if you start it from the command line in the right path. It doesn't seem that System Console needs any environment configuration from Quartus. On my system it is in C:\altera\*\quartus\sopc_builder\bin\system-console.exe but it may be different in the new versions without SOPC builder.
--- Quote Start ---
--- Quote End ---
As Im new to the Altera/quartus environment it took some time, but I think I found the solution to my "Thread" question. I missed to run command "initialize_systemconsole". So in CMD I can now run...
quartus_sh -s
This works fine!:) But now Im stuck on command "open_service".:(
The reason for me running in CMD is that Im calling CMD from C# code using a process call. I tried the same routines with system-console but I lost the handle to the process and I could not control it. Thats why I'm trying with CMD.
When I run
tcl> initialize_systemconsole
Info (345047): Preparing to create a connection to SystemConsole. This may tak
several seconds.
Info (345009): A connection to SystemConsole was successfully established on p
t 63525
/master}
To me this indicates a successfull connection to Systemconsole, anyone knows what I'm doing wrong?
Thanks!!
I did a reply, but it seems to be lost...
The answer to the thread question is that I forgot to "initialize_systemconsole", I'm a beginner ;-).
So type in CMD
quartus_sh -s
This work OK!, but next step is to "open_service" and this fails.
According to initialize_systemconsole functionality...
Description:
Initializes the connection to System Console and
registers all applicable System Console commands in the
current interpreter. This command must be run before any
other System Console commands can be executed.
Here it states that "all applicable System Console commands in the current interpreter."
But still "open_service" fail, it works OK when runned in "system-console.exe". I can also add that
I succeeded to run "claim_service" in CMD. If that is to any help.
Thanks for any assistance.
To close this thred.
To be able to call scripts, run commands via C#, process and StandardInput, StandardOutput. You need to use system-console.exe with arguments "--disable_readline --cli", like this...
ProcessStartInfo processStartInfo = new ProcessStartInfo("system-console.exe");
processStartInfo.RedirectStandardInput = true;
processStartInfo.RedirectStandardOutput = true;
processStartInfo.RedirectStandardError = true;
processStartInfo.ErrorDialog = true;
processStartInfo.Verb = "runas";
processStartInfo.WorkingDirectory = "C:\test
processStartInfo.Arguments = "--disable_readline --cli";
processStartInfo.UseShellExecute = false;
processStartInfo.CreateNoWindow = false;
Process process = new Process();
process.StartInfo = processStartInfo;
process.Start();
if (process != null)
process.StandardInput.WriteLine("cd C:\test");
process.StandardInput.WriteLine("source myscripts.tcl");
process.StandardInput.Close();
outputString = process.StandardOutput.ReadToEnd();
process.WaitForExit();
outputString now contains the data/feedback from system-console for Pass/Fail verification.
