17268 Discussions
"scfifo_component : scfifo" is not bound
I would like to know how to fix the binding problem of scfifo in modelsim (6.5b). I already added the altera_mf library but still the warning comes out ("scfifo_component : scfifo" is not bound) when I try to start the simulation.
altera_mf is a correct library for scfifo?
I found out that there is a mismatch in ports between the generated fifo.vhd and the scfifo of altera_mf_components.vhd
(ex. sclr, aclr ports)
What libary should I use?
Generated fifo file (using Quartus 10.1) Component mapping:
GENERIC MAP (
add_ram_output_register => "ON",
almost_full_value => 64,
intended_device_family => "Cyclone IV GX",
lpm_numwords => 128,
lpm_showahead => "OFF",
lpm_type => "scfifo",
lpm_width => 83,
lpm_widthu => 7,
overflow_checking => "ON",
underflow_checking => "ON",
use_eab => "ON"
PORT MAP (
clock => clock,
sclr => sclr,
wrreq => wrreq,
aclr => aclr,
data => data,
rdreq => rdreq,
empty => sub_wire0,
full => sub_wire1,
q => sub_wire2,
almost_full => sub_wire3
altera_mf_components.vhd (from Quartus 10.1 installed directory)
Component mapping:
component scfifo
generic (
add_ram_output_register : string := "OFF";
allow_rwcycle_when_full : string := "OFF";
almost_empty_value : natural := 0;
almost_full_value : natural := 0;
intended_device_family : string := "unused";
lpm_numwords : natural;
lpm_showahead : string := "OFF";
lpm_width : natural;
lpm_widthu : natural := 1;
overflow_checking : string := "ON";
underflow_checking : string := "ON";
use_eab : string := "ON";
lpm_hint : string := "UNUSED";
lpm_type : string := "scfifo"
port(
aclr : in std_logic := '0';
almost_empty : out std_logic;
almost_full : out std_logic;
clock : in std_logic;
data : in std_logic_vector(lpm_width-1 downto 0);
q : out std_logic_vector(lpm_width-1 downto 0);
rdreq : in std_logic;
sclr : in std_logic := '0';
usedw : out std_logic_vector(lpm_widthu-1 downto 0);
wrreq : in std_logic
end component;
Thank you.
I just fixed the problem.
I was mistaken in using altera_mf source file.
During binding problem I used the source file from this directory:
C:\altera\10.1sp1\quartus\libraries\vhdl
Problem fixed using thefiles in this directory:
C:\altera\10.1sp1\quartus\eda\sim_lib
Zeahr
