I would like to know how to fix the binding problem of scfifo in modelsim (6.5b). I already added the altera_mf library but still the warning comes out ("scfifo_component : scfifo" is not bound) when I try to start the simulation. altera_mf is a correct library for scfifo? I found out that there is a mismatch in ports between the generated fifo.vhd and the scfifo of altera_mf_components.vhd (ex. sclr, aclr ports) What libary should I use? Generated fifo file (using Quartus 10.1) Component mapping: scfifo_component : scfifo GENERIC MAP ( add_ram_output_register => "ON", almost_full_value => 64, intended_device_family => "Cyclone IV GX", lpm_numwords => 128, lpm_showahead => "OFF", lpm_type => "scfifo", lpm_width => 83, lpm_widthu => 7, overflow_checking => "ON", underflow_checking => "ON", use_eab => "ON" ) PORT MAP ( clock => clock, sclr => sclr, wrreq => wrreq, aclr => aclr, data => data, rdreq => rdreq, empty => sub_wire0, full => sub_wire1, q => sub_wire2, almost_full => sub_wire3 ); altera_mf_components.vhd (from Quartus 10.1 installed directory) Component mapping: component scfifo generic ( add_ram_output_register : string := "OFF"; allow_rwcycle_when_full : string := "OFF"; almost_empty_value : natural := 0; almost_full_value : natural := 0; intended_device_family : string := "unused"; lpm_numwords : natural; lpm_showahead : string := "OFF"; lpm_width : natural; lpm_widthu : natural := 1; overflow_checking : string := "ON"; underflow_checking : string := "ON"; use_eab : string := "ON"; lpm_hint : string := "UNUSED"; lpm_type : string := "scfifo" ); port( aclr : in std_logic := '0'; almost_empty : out std_logic; almost_full : out std_logic; clock : in std_logic; data : in std_logic_vector(lpm_width-1 downto 0); empty : out std_logic; full : out std_logic; q : out std_logic_vector(lpm_width-1 downto 0); rdreq : in std_logic; sclr : in std_logic := '0'; usedw : out std_logic_vector(lpm_widthu-1 downto 0); wrreq : in std_logic ); end component; Thank you.Link Copied
I just fixed the problem. I was mistaken in using altera_mf source file. During binding problem I used the source file from this directory: C:\altera\10.1sp1\quartus\libraries\vhdl Problem fixed using thefiles in this directory: C:\altera\10.1sp1\quartus\eda\sim_lib Thanks. Zeahr
