17245 Discussions
reading Memory initialisation file problem
Hi...
I have written a project which require a look up table which is stored in ROM i have created a .mif file to intialise the data in ROM
I am using Modelsim for simulation.
in the project folder i have project files, testbech and .mif file...
when i run the project it is not getting data from mif file.............what could be the problem please suggest.
Make the the megafunction file points to the correct path of the file. It doesn't matter if the mif file is in the project folder.
It is common problem when having mif file relative path determined from Quartus level (in megawizard) then moving to ModelSim the path may become wrong from ModelSim relative level.
The remedy is to make the path same from either Quartus or ModelSim folder i.e. put the mif at same level as both folders.
If you launch your simulation with a tcl script, you could also insert lines to copy the mif file from your quartus directory to the modelsim project one.
--- Quote Start ---
--- Quote End ---
they are in the same folder. mif file is not getting compiled .please tell me how to put mif file in the work directory.
I meant same level (not same folder) i.e. your structure like this:
- quartus (folder
- ModelSim(folder)
- files(folder)
then put mif in files folde1. so that way the path in Megawizard becomes:
../files/name.mif
which is correct from modelsim as well.
You may also just copy mif inside modelsim folder
Here is a TCL code example to copy all .hex and .mif files from a quartus directory to a modelsim one (workdir) :
set workdir $yourmodelsimdirectory
set memoryfilesdir $yourmemoryfilesdirectory
foreach datadir [list "$workdir"] {
foreach datatype [list "hex" "mif"] {
foreach g [glob -nocomplain "$yourmemoryfilesdir*.$datatype"] {
file copy -force $g .
You just have to adjust the paths set in bold to your directory structure.
An alternate method is to use the copy command with a double "\\". Specific example Below:
copy ..\\..\\..\\vivado\\14_5\\LM_Cases\\5_params\\Optimized1\\impl\\verilog\\*.dat
