signal tap
jaylong
I want to output the answers simulated in Signal Tap to a text file. What should I do?
FvM
try "Create Signaltap List File" in Signaltap file menu.
FvM
jaylong
I can't use that feature.
FvM
"can't use" means what, exactly? The function can be only used, if the signal tap window contains recorded data.
jaylong
I found out where the problem was. Thank you so much.
RichardTanSY_Altera
I believe your inquiry has been answered. Do you need further help in regards to this case?
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey
RichardTanSY_Altera
I believe your question has been addressed. With that, I will transition this thread to community support.
If you have any further questions or concerns, please don't hesitate to reach out.
Thank you and have a great day!
Richard Tan
