simulation error...
Error: Simulation results from J:/projects/uart_frq/db/uart_frq.sim.cvwf (0 ps to 20.0 ms) do not match expected results from vector source file J:/projects/uart_frq/uart_frq.vwf
Error: Logic level(s) do not match expected level(s)
Error: Logic level 0 does not match expected logic level X for node "cnt" at time 0 ps
Error: Logic level 0 does not match expected logic level X for node "frqout" at time 0 ps
Error: Quartus II Simulator was unsuccessful. 4 errors, 0 warnings
Error: Peak virtual memory: 123 megabytes
Error: Processing ended: Sun Sep 27 14:50:43 2009
Error: Elapsed time: 00:02:23
Error: Total CPU time (on all processors): 00:02:21
can someone tell me what is wrong???
You specified in the waveform file that you expected the "cnt" and "frqout" to be 'X' at the beginning of the simulation, which is not the case. You should change those to the real expected signals, or change them to "don't care"
