I am work at Quartus 9.1 SP1,the device is A2GX65,when i using SOPC to building a pcie system,some problem about interrupt is occured. i connect an irq port to pcie's RxmIiq port,but when i assert a irq to pcie,the pcie doesn't generate an interrupt to host. i browser the top module of sopc, find that sopc have tied RxmIrq_i to 0,and comment that "there is no irq connect ,so tied it to 0".that is not the true,because i does connect the irq port. so, i suppose that is a bug of SOPC @ Quartus 9.1 SP1,because at Quartus 9.0 SP2,there is no that problem. anyone others have this problem?Link Copied
Did you set the AVL_IRQ bit in Avalon-MM to PCI Express Interrupt Enable Register (Offset 0x50 of CRA Interface - Table 4-23 from PCI Express User Guide)??
I use the PCIex interrupt but not the port RxmIrq_i. I use the interrupt generation by writing the mailbox.- Mark as New
I have the same issue - there is a bug in SOPC builder 9.1. Check the Altera support solution rd02102010_251.
In my design the RxmIrq_i and RxmIrqNum_i inputs to "the_pcie" module in the SOPC toplevel are both set to 0. The slave irq outputs are left dangling. The workaround suggested doesn't work for my design - conversion circuitry from single interrupt lines to irq and irqnumber in addition to eventual clock domain crossing handling are also needed. Regards, Ove Brynestad- Mark as New
I too have run into this problem and their work around does not correct my problem as I have multiple interrupt sources. Would you be able to share the code that you have that works around this problem?
Unfortunately not - didn't take the effort to write it. However as a quick fix I just synced and 'or'ed the interrupts together and hardwired app_msi_num to zero. This solution is not viable but enables our driver SW developers to move on for now.
Altera says this will be fixed in 10.1 late this year. If you are generating interrupts using the mailboxes, this problem doesn't apply.
I've installed Quartus V10.1 and seems that this problem was not solved. I also tried the Altera's work around and I'm not able to get the interrupts on my PC.
Anyone solved this issue ? Best Regards L.Lessa
