specify depth of channel
Is there any way to set the depth of a channel? I see nothing in the documentation. I am getting compiler warnings about "Channel depths cannot be optimized".
I found some information about channel depth in the programming guide.
http://www.altera.com/literature/hb/opencl-sdk/aocl_programming_guide.pdf
Implementing Buffered Channels Using the depth Channels Attribute
You may have buffered or unbuffered channels in your kernel program. If there are imbalances in channel
read and write operations, create buffered channels to prevent kernel stalls by including the
depth
attribute in your channel declaration. Buffered channels decouple the operation of concurrent work-items
executing in different kernels
Here is an example:
channel int c __attribute__((depth(10)));
I found this information from:
"Implementing Buffered Channels Using the depth Channels Attribute" in
All that is needed is the depth attribute. Here is an example:
