state machine file
i create a state machine using the state machine file (.smf) or editor, but i have a problem i have two states, but quartuss II doesnt acept more than one transition to the same state, and in my design i have two transition to the same state(state1) , and one transition to to the other state (state2), and the same in state2, two transitions to state 2 and one transition to state1.
I need help, this is the vhdl that generated the programm and also this is the diagram.
-- Copyright (C) 1991-2009 Altera Corporation
-- Your use of Altera Corporation's design tools, logic functions
-- and other software and tools, and its AMPP partner logic
-- functions, and any output files from any of the foregoing
-- (including device programming or simulation files), and any
-- associated documentation or information are expressly subject
-- to the terms and conditions of the Altera Program License
-- Subscription Agreement, Altera MegaCore Function License
-- Agreement, or other applicable license agreement, including,
-- without limitation, that your use is for the sole purpose of
-- programming logic devices manufactured by Altera and sold by
-- Altera or its authorized distributors. Please refer to the
-- applicable agreement for further details.
-- Generated by Quartus II Version 9.1 Build 222 10/21/2009 SJ Full Version
-- Created on Tue Apr 27 18:06:02 2010
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY states IS
PORT (
clock : IN STD_LOGIC;
reset : IN STD_LOGIC := '0';
sa : IN STD_LOGIC := '0';
sb : IN STD_LOGIC := '0';
v : OUT STD_LOGIC
END states;
ARCHITECTURE BEHAVIOR OF states IS
TYPE type_fstate IS (state1,state2);
SIGNAL fstate : type_fstate;
SIGNAL reg_fstate : type_fstate;
SIGNAL reg_v : STD_LOGIC := '0';
BEGIN
PROCESS (clock,reg_fstate,reg_v)
BEGIN
IF (clock='1' AND clock'event) THEN
fstate <= reg_fstate;
v <= reg_v;
END IF;
END PROCESS;
PROCESS (fstate,reset,sa,sb)
BEGIN
IF (reset='1') THEN
reg_fstate <= state1;
reg_v <= '0';
ELSE
reg_v <= '0';
CASE fstate IS
WHEN state1 =>
IF ((NOT((sa = '1')) AND NOT((sb = '1')))) THEN
reg_fstate <= state2;
ELSIF ((NOT((sa = '1')) AND (sb = '1'))) THEN
-- Inserting 'else' block to prevent latch inference
ELSE
END IF;
reg_v <= '1';
ELSE
reg_v <= '0';
END IF;
WHEN state2 =>
IF (((sa = '1') AND (sb = '1'))) THEN
ELSE
END IF;
reg_v <= '1';
ELSE
reg_v <= '0';
END IF;
WHEN OTHERS =>
reg_v <= 'X';
report "Reach undefined state";
END CASE;
END IF;
END PROCESS;
END BEHAVIOR;
i forgot, i cant see, the state in the waveform file, is fstate, but it supossed that you add this signal like a TYPE:MACHINE, but it add me the signal like BURIED, when i put it manually two MACHINE makes me error
