17255 Discussions
stratix II GX high performance ref. design test failed
Hi.
I'm trying to run the PCI E high performance reference design (an 456), on a Stratix II GX PCI Express developement board (EP2SGX90F1508C3). I programmed the board with de .sof file available in the PCIe_hiperf_s2gx_agx.zip file. The sop file is top_x4.sof in /PCIe_hiperf_s2gx_agx/sip_gen1_x4_stiigx/ directory. I installed the demo driver and software executable used for running the reference design on the board.
I pressed "Run Endpoint DMA" and then the program crashed. This is a screenshot:
i50.tinypic.com/zvoiub.jpg
This is the pcie_log.txt :
============================================================================ PCI Express performance demo log ============================================================================ =========================================== Scanning PCIe Board =========================================== =========================================== Scanning PCIe Board =========================================== =========================================== Scanning PCIe Board =========================================== o Stratix II GX soft IP endpoint supporting x4 lanes at Gen1 rate o Training Status : - 4 lanes running at 2.5 Gb/s - Maximum read request : 512 bytes - Maximum payload write : 128 bytes o Application layer interface : 64-bit Avalon-ST o The endpoint uses a 32768-byte on-chip memory buffer =========================================== Scanning PCIe Board =========================================== Descriptor Table content: | 0x0 0xfffa 0xfffb 0xfffc 0xfffd | 0x4 0x203e6 0x0 0x0 0x13412068 | 0x8 0x20400 0x0 0x0 0x29e04000 | 0xc 0x20400 0x0 0x0 0x25dc5000 | 0x10 0x20400 0x0 0x0 0x26f86000 | 0x14 0x20400 0x0 0x0 0x2834f000 | 0x18 0x20400 0x0 0x0 0x5ee0000 | 0x1c 0x20400 0x0 0x0 0x5da9000 | 0x20 0x20400 0x0 0x0 0x1340a000 | 0x24 0x20400 0x0 0x0 0x144a3000 | 0x28 0x20400 0x0 0x0 0x1179c000 | 0x2c 0x20400 0x0 0x0 0x2af6d000 | 0x30 0x20400 0x0 0x0 0x26f8e000 | 0x34 0x20400 0x0 0x0 0x282bf000 | 0x38 0x20400 0x0 0x0 0x2bde0000 | 0x3c 0x20400 0x0 0x0 0x5dc1000 | 0x40 0x20400 0x0 0x0 0x30a9a000 | 0x44 0x20400 0x0 0x0 0x141e3000 | 0x48 0x20400 0x0 0x0 0x2592c000 | 0x4c 0x20400 0x0 0x0 0x2af75000 | 0x50 0x20400 0x0 0x0 0x26f9e000 | 0x54 0x20400 0x0 0x0 0x28417000 | 0x58 0x20400 0x0 0x0 0x2c508000 | 0x5c 0x20400 0x0 0x0 0x5dc9000 | 0x60 0x20400 0x0 0x0 0x14c72000 | 0x64 0x201c2 0x0 0x0 0x146e3000 | 0x68 0xcdcdcdcd 0xcdcdcdcd 0xcdcdcdcd 0xcdcdcdcd | 0x6c 0xcdcdcdcd 0xcdcdcdcd 0xcdcdcdcd 0xcdcdcdcd Programing DMA Register EP ADDR: 0x0 DW0 : 0x40019 EP ADDR: 0x4 DW1 : 0x0 EP ADDR: 0x8 DW2 : 0x24351840 EP ADDR: 0xc DW3 : 0x18Can anybody help me?
Thank you very much!!
